Thoughts on a bunch of DACs (and why delta-sigma kinda sucks, just to get you to think about stuff)
Discussion in 'Dedicated Source Components' started by purrin, Dec 5, 2013.
385 386 387 388 389 390 391 392 393 394
396 397 398 399 400 401 402 403 404 405
  1. Ableza
    Well, anything is possible and damage due to transit could happen, especially if the packaging was insufficient.  But bottom line is if you bought on Ebay and used PayPal, then you are protected and if the seller will not make it right for you, file a claim with PayPal.
  2. Wildcatsare1
    Thanks, yes on both counts, Ebay and PayPal. Mr. Poon (he is a great Guy BTW) sent me the schematics and he is talking me through a couple of things. Need to get a new battery for my multimeter so I will find out this PM.
    It was packed very well, the Seller says he is a Tech with an electrical background and the unit was working when he sent it to me. He only insured it for $100.00 with Canada Post. Here's a pic of the transformers, any idea on the replacement costs?
  3. Ableza
    It is HIGHLY unlikely for a transformer to be damaged due to shipping.  It takes heat and power to damage transformers, normally. Much more likely to have been caused by shipping would be something coming loose or for the motherboard to get knocked off its mounting and perhaps shorting to ground.  I would be very surprised if a transformer was good when shipped and then bad when delivered.  You might look under the main board and see if a screw or something is wedged underneath... or look for a loose connection somewhere...
  4. Wildcatsare1
    Thanks, will take a look when I get home. If it is a transformer I will have to negotiate for the cost of replacement or just ship it back for a refund.
  5. AudioBear
    Why do you think it was a transformer?  It's more likely a dislodged screw or loose contact as Ableza has pointed out.  Look for cracks in the tracks on the printed circuit boards, loose connectors, a loose wire at the power plug, etc.
  6. Sonic Defender Contributor
    I would just go for the refund and hit reboot. You could be pulling your hair out trying to find the fault if it isn't very obvious. You have other DACs right, or is this DAC supposed to be so good that it is worth the effort? Good luck there buddy.
  7. prot
    And other people compared $2, $200 and $2000 DACs and found that they cannot tell the difference http://www.tomshardware.com/reviews/high-end-pc-audio,3733-19.html. That was a pretty professional test, performed 100% by the book.
    Could you tell us more about the devices you tested and how did you do it?
  8. LingLing1337
    Could you first tell me which devices you've used/compared/ABXd?
  9. drez
    In this interst of keeping this thread on topic I made my reply to prot's post on "Testing claims about the sound of different DACs" thread in Sound Science
  10. purrin
    LOL, that article has been mentioned several times already. I too could line up several craptastic DACs from $100 to $4000 and probably have the $100 one sound the best. Those guys were using the builtin headouts of some of those DACs too. The findings in that article aren't that much out of whack if you've actually heard the combinations they've tested.
  11. Wildcatsare1
    OK, update....checked the ohms across the 230V point on the board, no idea what it's actually called but Mr. Poon said anything over 20 was fine and I am getting 21.3. No visible cracks on the board, loose connections, etc., stil blowing fuses. Guess I'll be sending it back:disappointed_relieved:.
    Before I do I'll check with Mr. Poon one more time to see if he has any ideas. Those PCM63 P-K's are beautiful though....
  12. yfei
    Actually in the resolution, detail department, I found Dell XPS 9100 desktop PC is the best (integrated realtek chip, probably the whole audio section on the motherboard is only $2).
    I use it as a reference to compare with DACs, it beats all DACs I have tried from few hundred to $1xxx.
    I know this sounds crazy, all DACs are not as detailed, as transparent as a $2 audio system.  Until I got Hilo.
    Note that I am not talking about sound quality,    XPS 9100 internal sound chip is NOT musical, NOT smooth, frequency response is not flat, ....      Only talking about details and clarity.
  13. BassDigger
    The postal insurance should be the seller's responsibility; if he didn't insure enough, that's his problem.
    If he seems helpful, he says he's a tech, maybe he'd like to have a look at it, see if he can fix it and return, or refund you, depending on what he can do or how you feel.
    It depends on how much of a bargain you feel you got, what comparable alternatives there are and do you trust the seller?
  14. prot
    You and I may or may not agree with the conclusion but I doubt that any audio-joe will hear anything different. That means over 99% of the people .. and since we are discussing the SQ as a subjective matter of oppinion, that percentage is very relevant.
    I have no reason to doubt the people who wrote that article. Tom's is a well known PC hardware-test site.. one of the oldest and most respected. Also, it is not the only report to say that the $2 MB sounchips are really good nowadays.
    I do however have every possible doubt about empty statements like the above "I tested 3 DACs and they did sound very different" .. that is not even information ... and probably wouldve been a much better idea to just ignore it.
  15. frenchbat
    Wait, what ? You think that using different amps (in this case integrated headout) to compare DACs is A-OK as a methodology ? Seriously ...
