- Aug 2, 2008
You think the Yggy is all about that recycled megaburritto filter to avoid huge costs in designing a better filter?
- Still a custom filter. Not cheap. They still needed a guy to code for the SHARC. I met that guy. It's not like you can copy code meant for Motorolas from twenty years ago. Lots of other stuff too to code too, e.g. in loading up bits in sequence to the AD5791 since AD5791 is not an audio chip and doesn't take native digital audio formats. Algorithm is one thing, actual coding / implementation of an algorithm is another. Schiit took an extremely difficult path to make that DAC. This of course does not make the efforts of others like Chord any less significant.
- FWIW, the custom filters of other DACs out there are also based on existing algorithms.
- Why change something that works well? there's a reason why GM stuck with its pushrod motor with the Vette despite it being "old" technology. in both cases, the implementations are new takes on old stuff.
- Finally, if you've actually written software or firmware, or even designed something simple, you would understand. Dude, please just give it a rest. Seriously, just shut the **** up because it's obvious you don't know what the **** you are talking about. It's one thing if you are trying to understand, but you are just being a ******** armchair DAC designer. In the end, it's all about sound. What does it matter to you if you haven't heard it, don't plan on hearing it, don't even plan on buying it, or can't afford to buy it. If you smell ****, say so once and please move on.
