Hi.. Just curious .. Is there any actual digital high res music file which can utilise all the dynamic range says even at full 16 bit? If yes does it mean we have to turn on the volume i.e in excess of 100dB to hear the peak? thks
Maybe this is difficult to explain, but I'll have a go (with my own limited understanding):
The dynamic range is the difference between the loudest bits and the quietest (the noise floor). In this case we're talking about the limitations of both the recording format (cd,dvda) and playback device (the converter, dac). The perfect format and system combination would be able to replay a 100% accurate and realistic dynamic range. This does not exist. Because of this, recordings are dynamically compressed. This means the quieter parts are made louder (to keep them audible above the noise floor) and the loudest bits are made quieter (to keep them within the capabilities of the format).
On top of this, the technical limitations of the playback equipment also reduces the dynamic range, the 16 bit format and converter being one example of this.
Basically, you will always "hear the peak", the loudest parts (unless your volume control is turned too low). A 100dB sound, on the recording, may play anywhere between 1dB or 120dB; it depends on where you've set your volume control (and the capabilities of your system).
Actually, the concern is more at the other end of the spectrum; with a wider dynamic range, the quietest bits will be quieter; you may miss them if your volume is turned too low, your system lacks resolution or its noise floor is too high. This is why dynamic range is so important for classical music, because there's such a difference between the whole orchestra playing, or just a single triangle being tinged; with a realistic dynamic range, the full orchestra is maybe 110dB louder than the triangle.
True 16 bit recordings are 105dB maximum (I think). That's the difference between the loudest and quietest parts. (But most are significantly less, for 99% of the recording.) Then with the technical restrictions of your system, this is reduced further; maybe to less than 100dB. But despite this, you can still make the loudest parts play at 110dB or more, if you want, but then the quietest would be maybe be at 10 or 20dB, when they should be 5dB; they would be louder than reality. Alternatively, you can play a true 110dB recorded sound play at 50dB, just because you've set the volume that way.
More bits equals more dynamic range, but this has a trade-off, IMO; 24 bit digital (or DSD) may appear technically superior, but it creates other (worse) problems to do this. 16 bit (CD or WAV) and multi-bit (R-2R) dacs have enough headroom, and are the way to go, as far as I'm concerned.
(If anyone wants to revise, improve upon or put right my theory or figures, be my guest. But please use confirmed facts and figures, not 'guestimates'; I've used more than enough of those already.
