Thoughts on a bunch of DACs (and why delta-sigma kinda sucks, just to get you to think about stuff)
Jan 12, 2014 at 2:17 PM Post #256 of 6,500
Purrin, did you make the cable between the OR5 and M7 or request for Kingwa to change the i2s connection for compatibility with the offramp?
Jan 12, 2014 at 2:23 PM Post #257 of 6,500
  It appears all the "VERY GOOD STUFF"  on page 1 had the benefit of a good DDC like the OR5 whereas the other stuff were driven from the stock USB inputs or the digital outs of consumer grade pc's. having first hand experience with a decent DDC (battery driven SOtM dx-USB HD), SPDIF is hands down superior to USB. I am curious to know how the rankings would have changed had all the DAC's been compared like-for-like.
I doubt the rankings would have changed much if at all. The OR5 will only improve on certain kinds of things, and even then it can only do so much. We actually did try the OR5 on a few of the lower cost DACs, but what we found is that these DACs just didn't scale that much. For example, someone had asked me if the OR5 was worth it with the Gungnir Gen 1 USB. I replied it wasn't worth it considering the low cost of the Gungnir and the small gains from the OR5 with it. In other words, the OR5 does give the Gungnir the technical prowess of the PWD2 via USB; and it doesn't make sense to pay $1100-$1500 for a USB converter for a $800 DAC.
Generally, if we felt the OR5 didn't improve a DAC significantly enough to change its ranking, we didn't bother. Just too much work and hassle trying to set up each DAC-Off event. Heck, we still have notes from a few other DACs which we need to compare and do write-ups on. The SABRE DACs all tended to have good USB implementations. The few DACs I wished we had a chance to try the OR5 on were the Lavry, M51, Luxman, Gamma2. The Gamma2 would have mainly been out of curiosity since it's DIY and usually obtainable used for a little over two hundred dollars. In any event, only the top three DACs, the Alpha, PWD2, and especially M7, improved significantly with the use of the OR5.
Originally Posted by mcduman /img/forum/go_quote.gif
One could have the impression reading earlier posts that gungnir's gen2 usb implementation is superior to SPDIF. Nothing could be further from the truth...
That's too general of a statement to make. Ultimately, it probably depends upon the quality of the SPDIF source. I found the Gen 2 USB implementation to be superior to SPDIF from two sources I deem as "decent" (a PC and a modified Marantz CDP), but it was so close that I can't be sure. The gains from the OR5 into the Gen 2 are very minimal. We will need to compare the Gungir Gen 2 USB with the Denon CDP, which I know is superior to my PC and Marantz. Maybe I'll ask Schiit if they have an old Theta CD transport l can borrow to add to the mix.
Jan 12, 2014 at 2:38 PM Post #258 of 6,500
Reaaally looking forward to your opinion of the Bifrost Uber and how it'll be rated versus Gungy. God I'm impatient!
Two ninja's have an Uber-Frost right now along with two three other DACs in this list. We are still sharing notes and have yet to make a final determination on its ranking. This is my very early assessment: Uber-Frost w/ Gen 2 USB is way too close to the Gungnir. Slightly less dynamic and slightly more grainy / less smooth. Equally resolving.
I actually made my own cable. Then I realized I could make a special request with Kingwa because Prepoman made such a request with his M7. Just easier this way because it allow me to "roll" standard Ethernet cables. Just kidding. I don't obsess about stuff like that too much. Maybe a little a bit.
Jan 12, 2014 at 2:56 PM Post #259 of 6,500
Considering a uber bifrost w/ usb gen 2 is $510, do you think the bifrost is better value wise compared to the gungnir w/ usb gen 2 at $850 when used with a SE amp?
Too late for me on that note, but I'm sure many others are wondering the same thing.
Jan 12, 2014 at 3:17 PM Post #260 of 6,500
Purrin,
if you have your setup comments, which outputs did you listen to the Hilo with? Your description of a 2D presentation I noticed out of the monitor. The balanced outs gave a better soundstage using two DACs. But maybe that was how you tested it. I didn't see anywhere how it was set up.
Jan 12, 2014 at 5:17 PM Post #261 of 6,500
The singled ended outputs were used with the Super 7 (headphone). I used the balanced outs to the Mjolnir (speaker rig).
Jan 12, 2014 at 5:19 PM Post #262 of 6,500
I know, I know. That what's we are trying to decide right now and it's killing us. There is no doubt however that the Gungnir is better, even with the SE outputs.
Jan 12, 2014 at 7:04 PM Post #263 of 6,500
Since the Gungnir is reclocking the OR5 (adding back jitter) I wonder how the über will do with the OR5. I know it's overkill but it'd be fun to try out...not that you need more setups to try. Give it a whirl.
Jan 12, 2014 at 8:48 PM Post #264 of 6,500
Hi, I actually have a p1u, do you think the gungnir or the matrix x-sabre is a better fit? Thanks
I think the better dynamics of gungnir will suit the character of p1u, however seems like x-sabre is more resolving.
Jan 13, 2014 at 11:08 AM Post #266 of 6,500
I may be misunderstood. What was the Lynx Hilo's outputs when tested?
I used the SE RCA outputs of the Hilo when the Super 7 amp was used. The balanced outputs XLR outputs of the Hilo were used with the Mjolnir.
Hard to say. I think it depends which direction you want to go. Both DACs are good, but excel in areas where each other don't.
Jan 13, 2014 at 12:13 PM Post #267 of 6,500
A very interesting thread!
I'll be watching the Bifrost vs. Gungnir comments!
Jan 13, 2014 at 5:19 PM Post #269 of 6,500
May be another week. I need to stack the following together for a another DAC-Off.
  • Gungnir
  • Bifrost
  • M7
  • PWD2
  • Metrum Quad
Jan 14, 2014 at 2:54 PM Post #270 of 6,500
  • Gungnir
  • Bifrost
  • M7
  • PWD2
  • Metrum Quad
have you heard the BDA2 ?
