You want the black packaging version. Some say the clear/frosted version are the same, but the material feels thinner and it doesn't give the same clarity on the opposing ends of the spectrum. I know the Deep Mounts are expensive, but they're also extremely comfortable and they offer a sonic profile I haven't been able to get with any other tip. When that profile nails what you're looking for, you literally can't get it anywhere else which makes it all worth it in the end. I currently use the Deep Mounts on 4 pairs of IEMs permanently and three more on a rotating basis.
This pic shows the packaging. This is the pic of the multi pack, but you can also find them in single size packs once you know what size you're looking for which often depends on the IEM nozzle size for me.
I wanted to say thank you. I just got these through the post and these are the best tips yet. I was using the Clarions for a while as part of rotating round the tips I have but these are the best yet. Still got some Eletech Baroque tips coming but so far these ones top the list and are probably most likely to win out.
