Skylab
Reviewerus Prolificus
My thinking exactly. The REASON for it is that it sounds much better just off battery, and so Ray didn't want to enable it's use with the charger. It will last a week solid played 8 hours per day. That is enough for me for sure.
Here is the extent to which I can speculate:
Linn LP 12 = good
F117 Nighthawk = good
Then,
Linn LP 12 + F117 Nighthawk = good
Of course it may not end up that way for sure, but odds are it would.
Originally Posted by shaizada /img/forum/go_quote.gif I believe it works 8 to 10 days if used 8 hours a day on one charge. If it can do even half of that, I don't think it will be much of a problem. I also believe the battery gets charged up to full in 1 hour. I'm sure Ray will chime in further. |
Originally Posted by vo_obgyn /img/forum/go_quote.gif Yeah, "speculate" probably isn't the best word. Just wondering about how the preamp would sound in a Linn set-up. You're right, to take something to be true on the basis of insufficient evidence - that is "speculate" - is not a good idea. Good pick up shaizada. |
Linn LP 12 = good
Then,
![smily_headphones1.gif](http://www.head-fi.org/forums/images/smilies/smily_headphones1.gif)
