borisov57
- Jul 11, 2007
Yes, that is about everything. There are also some small lytics around op-amp-s, which I changed for polypropylen. Black gate-s should be as good and probably better. But this is minor thing.
I did not try any other high voltage supply and output caps, you should refer to Audiocats to find out, which are best.
Supply resistors are 100 ohm and 22 ohm to compensate for higher supply current of OPA against Toshiba amps. If you plan to try AD8599, they should be even lower or no resistors at all.
Power supply in my case is SiC diode rectifier, RCLC filter ( 2 x 33000uF ) and then low noise discrete 3.6 V regulator. Regulator is not my design, so I can not go in details about it.
Best regards and have a lot of fun,
borisov57
Originally Posted by marcus1 /img/forum/go_quote.gif Thanks Boris; last question :*) Does the above (along with the new OPA1642 and resistors in power supply filters) accurately describe your current set-up? Thanks again |
borisov57
