The RMAA (RightMark Audio Analyzer) Source and Audio Device Measurement Thread [Overview of Measurements in Post #3, Tutorial in Post #2]
Sep 18, 2016 at 7:59 AM Post #61 of 255
I tried to use a Zoom UAC-2 to replace my aging E-mu 0404 USB, which doesn't have a lot of support anymore. What looked good on paper were the Burr-Brown converters and the claimed dynamic range and signal-to-noise ratio. So I ordered one and tested it. It feels solid and the build quality is really nice. It's also good for playing software instruments because of the low-latency USB 3.0 interface. And sure enough, it beats the old E-mu for on noise and dynamic range.
Noise levels
RMAA results
But look at the distortion! The converter chips can't be this bad. Sure, you probably won't hear it when playing music, but I was hoping to have this unit do double duty in a measurement rig. It looks like the analog electronics surrounding the converters aren't up to the same quality as those Burr Brown converters themselves.
1kHz, THD+N
IMD
What's worse is the frequency response of the line out. I did not find a way to defeat this peak in their mixer app:
Frequency response
There's no reason to have this in a modern audio interface, especially one that costs $250 US. So, if you're thinking of picking up one of these to make audio measurements, keep looking.
Oct 15, 2016 at 1:20 PM Post #62 of 255
Luxury & Precision L3 Pro:
No load:
Triple.Fi 10:
Various loads:
-> Around three Ohms and identical to the L3 as the same amp chips are used.
Oct 15, 2016 at 1:25 PM Post #63 of 255
Hidizs AP60:
Simple loads:
-> Consistent roll-off towards the sub-bass.
Triple.Fi 10:
-> Identical roll-off towards the sub-bass. The output impedance is rather around 1.5 Ohms than the stated 0.1 which is however still good.
Oct 15, 2016 at 1:33 PM Post #64 of 255
Cowon Plenue M2:
No load (digital filters):
Various Multi-BA loads:
-> The output impedance is stated to be around 1 Ohm which seems to be true according to the result.
JetEffect 7 settings (partially different scale):
BBE:
Mach3Bass:
EQ bandwidth (Q-factor):
EQ adjustments per single frequency band slider:
Extreme bass boost (BBE and Mach3Bass maxed out, various EQ bands maxed out, some treble bands adjusted):
Oct 26, 2016 at 12:52 AM Post #66 of 255
Oct 26, 2016 at 8:55 AM Post #67 of 255
Oct 26, 2016 at 9:18 AM Post #69 of 255
  @reginalb
Do you have some loaded and unloaded measurements of the Nexus 6? I'd really like to add them to this thread.
I didn't have input set to stereo, but here they are:
Nexus 6 No Load:
Nexus 6 Merlin Load:
The Merlin is a tough load. My AK300 and ZX1 both perform nearly identically to this, but with more dropoff in the treble range. Merlins are 12‎Ω.
by the way, I don't see them in post 3, but I did post results on the Sony ZX1 and AK300 as well. I think they're just unloaded, I'll add Merlin load graphs to them. Here is the Nexus 6 compared:
They all have a round +.5dB in the low to mid range, but above about 8k the N6 is around .25-.5dB closer to neutral than the AK300, and around .75-1dB closer to neutral than the ZX1
Oct 26, 2016 at 9:25 AM Post #70 of 255
@reginalb
Thanks, I have added the measurements to the 3rd post.
Yeah, I saw the unloaded measurements back when you posted them but a straight line without any load is no sorcery anymore these days, so to see what devices are multi-driver-IEM-friendly when it comes to output impedance, measurements with critically reacting loads are mandatory.
Oct 31, 2016 at 5:43 PM Post #71 of 255
What a great thread. When I get a spare moment I shall take readings from a QP1R and a Plenue S and report back.
Nov 1, 2016 at 1:30 PM Post #72 of 255
I'm really looking forward to seeing some loaded measurements of the Questyle.
Nov 1, 2016 at 6:06 PM Post #73 of 255
While I can't help you there, I did finally get around to adding loaded measurements to my ZX1 and AK300 posts:
http://www.head-fi.org/t/800208/the-rmaa-rightmark-audio-analyzer-source-and-audio-device-measurement-thread-measurements-in-post-3-tutorial-in-post-2/30#post_12678630
http://www.head-fi.org/t/800208/the-rmaa-rightmark-audio-analyzer-source-and-audio-device-measurement-thread-measurements-in-post-3-tutorial-in-post-2/30#post_12678536
Alas, I won't be able to do the more interesting Merlin load for a while. I just bought a house, and we're sleeping on a mattress on the floor while we await some furniture deliveries. I use my Merlins in bed, and after listening to them, I set them on the floor. My wife stepped on and shattered one of them.
Almost gave me permission to order a set of v2's, but alas, UM is going to repair them. Still I have to get impressions done, ship them to China, and then wait. So no interesting loads, as I said, for a while.
Nov 1, 2016 at 7:15 PM Post #74 of 255
Alas, I won't be able to do the more interesting Merlin load for a while. I just bought a house, and we're sleeping on a mattress on the floor while we await some furniture deliveries. I use my Merlins in bed, and after listening to them, I set them on the floor. My wife stepped on and shattered one of them. :(
Nooooo! I feel your pain
Nov 2, 2016 at 9:11 AM Post #75 of 255
  Cowon Plenue M2:
Wow look at those y-axis labels! About a +21dB bass boost! Have you listened to it? Even that Mach10 bass seemed like it would muddy other frequency bands. But over 20dB of bass boost, can you even hear any other content?
