UntilThen
- Jun 16, 2015
There's no build difference between an Osram and GEC L63 as they are the exact same tube from the exact same Brook Green works ; Hammersmith factory. As @leftside correctly noted; the only difference is the sticker that was stuck on it.
Branding a tube as it fit the marked was very common and at Marconi Osram Valve company; they had options .
As can be found in "Saga of the vacuum tube" by Gerald FJ Tyne
To those who are interested in some more history of vacuum tubes I highly recommend this book.
The best thing you can do is to actually listen to those tubes yourself and Stevenvalves has heard all those tubes. His collection is so big, he even sells privately to some friends who are sellers on eBay.
