jcx
- Jul 24, 2002
quote:
Originally posted by ppl since the Op-Amp is receiving it's feedback from it's own output rather than from the output stage the Phase shift of the output stage will not impact Phase margin as much as with the conventional method of one overall feedback loop. In most cases this removes the requirement of using Phase lead capacitance around the op-amp and allows the use of modest bandwidth Output stages.
Of course the above quote touches on one of the more misleading concepts floating around these forums about the inner feedback loop; for the values in the PPA schematic the capacitive feedback from the parasitic capacitance of R6 is ~ 4X larger than the resistive term at the closed loop corner frequency of the amplifier without even adding in the larger layout related capacitance of the left ends of R5,6 bringing op amp output and negative input to adjacent pins of a socket – so yes R6 has aided stability by reducing phase shift but due to parasitic capacitance and not by any virtue of high inner loop gain set by resistive divider ratios (I’ve assumed GBP AD8610 = 25 MHz, loop gain = 11, parasitic cap ~0.3 pF; you should add ~1 pF for the socket and maybe 1-3pF more for the lacquered metal end caps of R5&6 touching)
Additional consideration of the AD8610 8&15 pF diff&common mode input capacitance makes it hard to know how much credence to place in sweeping statements about noise gain compensation when in PPL’s published circuit the effects of local capacitive feedback are of the same magnitude as the resistive feedback at the closed loop corner frequency. The capacitive effects quickly become dominant when the loop gain is lowered to 2-4X unless you lower feedback resistance as gain is increased – which then moves even further from Jung’s recommendation to match input and feedback Z to minimize the influence of the input capacitance nonlinearity
I have no problem with the idea that the Jung multiloop with unity gain output buffers may be a “sweet spot” among op amp based amplifiers for audible and DIY tweakablity but I think optimizing this topology or moving (hopefully advancing?) on to other circuit topologies can be aided by a good engineering understanding of the circuit
