The Nameless Guide To PC Gaming Audio (with binaural headphone surround sound)
Oct 25, 2012 at 10:12 PM Post #889 of 4,136
Hmm!
Too bad my job won't start earlier than sometime next week, and payday a bit after that. That's quite a sale though, is it about $35 off regular?
$35, give or take, after taking shipping costs into account.
Oct 25, 2012 at 11:23 PM Post #890 of 4,136
Do you still recommend downloading the Titanium HD drivers you have listed in the OP?  Does that include the software interface piece of it as well?
Know any good guides for setting up the best sound quality on the Titanium HD?
Oct 26, 2012 at 1:35 AM Post #891 of 4,136
I do. Instructions on what to install in what order are contained within the archive.
As for sound quality, that largely depends on whether you're using it for gaming or music. For gaming, you generally want to stay in Game Mode for obvious reasons. For music, you may instead want to opt for Audio Creation Mode so you can have bit-matched playback through ASIO, unless you use Winamp with the OpenAL output plugin, for which you'll want to stick to Game Mode. (Oh, and I never, ever use Entertainment Mode. No need for it.)
The Crystalizer stays off. EQ and bass boost are set to taste, but do make sure that the sound isn't clipping, especially with volume set high (at 100%, any level of bass boost or positive EQ WILL clip, but at around 25-35%, you have a lot of headroom for upwards adjustments).
Speaker setting within the X-Fi drivers should be set to Headphones while the Windows setting should be set for 5.1. (This will not degrade stereo sources in the slightest, from my testing. It sounds exactly the same.) Then you can toggle CMSS-3D Headphone on for when you're gaming and need a positional advantage, and turn it off for when you want a clean stereo signal.
Oct 26, 2012 at 5:30 AM Post #892 of 4,136
I have a X-Fi Titanium HD, and I find THX Trustudio Pro (surround mode) much better than CMSS-3D. CMSS-3d makes the sound awfully thin and artificial, robotic-like.
THX Trustudio works the same way: you set the game/windows to 5.1, the console launcher to headphones, enable the THX surround mode and go.
The best part is that I never have to change the drive mode again. Its always on entertainment mode now.
Oct 26, 2012 at 10:32 AM Post #893 of 4,136
Isn't the Titanium HD capable of giving 7.1?  Why do both of you suggest 5.1?
Also without an external amplifier (directly plugging my headphones into my sound card), what's the best way to connect my headphones?  Should I just use the headphone jack?  I keep hearing things like RCA and optical mentioned but I'm not quite sure what they're good for.
Oct 26, 2012 at 1:20 PM Post #894 of 4,136
No the Titanium HD do not have analog 5.1 outputs. The only way to get 5.1 out of it is to use Digital Encoders. Other wise the sound card is a stereo card. I think you getting the Titanium HD mixed up with the orginal Titanium that does support 7.1.
Oct 30, 2012 at 1:37 AM Post #895 of 4,136
THX TruStudio Surround may impact the sound quality less, but it's dreadful at positioning by comparison (at least to my ears), and positioning is the exact reason why I use such technologies in the first place.
Also, it's only available in Entertainment Mode. That makes it next to useless for me given that I still have a lot of DS3D/OAL games that only work right in Game Mode, since that's the mode where the X-Fi DSP's hardware acceleration can be truly utilized. That means either CMSS-3D Headphone, plain stereo (which sounds like total crap in those games), or if it's an OpenAL title, fiddle around with Rapture3D, OpenAL Soft, AeonWave, etc. and hope they work perfectly.
But as always with binaural mixing tech, YMMV, and it's up to you to determine the balance between sound quality and positioning accuracy.
That's the only reason I advise setting Windows to 5.1 instead of 7.1 for HRTF mixing; the Titanium HD just doesn't support 7.1 at all.
It's not that big a deal to me, really. The important thing is that front and rear cues can still be distinguished in games with software-mixed audio.
Oct 30, 2012 at 11:22 AM Post #896 of 4,136
Ah my bad.  You're right.
Nameless, so you're saying I can leave 5.1 on even in Audio Creation mode when I'm listening to my music (iTunes or whatever)?  I've been using the bit-matched option and I think it's making a little difference in sound quality.  What about the master sampling rate?
Oct 30, 2012 at 3:15 PM Post #897 of 4,136
That's what I do, and it still doesn't sound any different from stereo.
The thing about bit-matched playback is that when you use an ASIO plugin, the master sampling rate changes on-the-fly according to the source, so you don't have to switch it manually. This doesn't work for WASAPI exclusive mode when using Audio Creation Mode, however.
Oct 30, 2012 at 6:08 PM Post #898 of 4,136
...THX TruStudio Surround may impact the sound quality less, but it's dreadful at positioning by comparison (at least to my ears), and positioning is the exact reason why I use such technologies in the first place.
Honestly... as I said before, I haven't made a definitive opinion yet, but I have yet to experience CMSS-3D to surpass THX TSP for positioning accuracy or really much directionality at all except during panning. Probably just one of those YMMV things. Does the first CoD have DS3D or OpenAL? I have that game for mac... Win8 Pro should be arriving soon from newegg, but I'm going to send it back because Microsoft is selling it for about half the price, direct, for people that used the consumer preview. I don't think the Win8 Pro deal is an OEM version, either.
Oct 30, 2012 at 6:59 PM Post #899 of 4,136
The Valve dev at the Steam for Linux talk mentioned in passing that they were using OpenAL. What implications does that have for gaming audio in Source games on Linux?
Oct 31, 2012 at 2:30 AM Post #900 of 4,136
I sure hope that carries over to Windows...though as for Linux, we'll probably have to rely on OpenAL Soft or AeonWave's HRTF implementations, especially since Creative's Linux driver support is almost nonexistent. (No hardware OpenAL for X-Fi cards on Linux, for instance.)
That said, I'm not too surprised they'd use it for Linux given that Loki Software (an old developer specializing in Linux game ports) specifically developed it to enable 3D positional audio in Linux, if I'm not mistaken with the API's history. It was only later that it got taken up by Creative.
CoD1 uses DirectSound3D, so make sure ALchemy's configured properly...wait, you said Mac, in which case that can't possibly apply because DirectSound3D, like the rest of DirectX, is exclusive to Windows. That means they either did all the sound mixing in software or refitted it with OpenAL.
As you know, I'm not all that different from Mad Lust Envy when it comes down to speaking frank, unsweetened opinions about audio tech, though I can agree to disagree. I just want to figure out how people can hear the same things so differently; a lot of it probably has to do with individual HRTFs, the condition of our ears (still need to go see an audiologist), etc.
