MrEleventy
- Oct 24, 2012
Not really. If you search around the FS forums, you can find some decent deals. Even new things like the Maverick Audio D1 is around 250 shipped and that takes optical in. Or you can buy a decent dac w/ a optical in and tack on an amp. SMSL Dac + magni/vali/o2/E09K/whatever would only set you back around 200.Would the SniperCzar method of routing your processed audio to a USB connected DAC be viable as well? From my own researching DAC/Amps that support optical are tough to find without putting down at least $300.
E: btw, SniperCzar method does work, the con is the sound quality isn't as good.
