The iBasso Dongle DAC Thread – DC07 Pro | DC Elite | DC06 Pro | DC04 Pro | DC03 Pro | ...
May 13, 2025 at 10:21 PM Post #1,923 of 1,929
By the way, i just got an DC07 Pro and FYI, keep the display off.
This is the measurement with the display on
This is the measurement with the display off
As they are not finished and just first tests/samples, ignore the measurements otherwise. But this is the first thing i noticed. If the display is on, its suddenly significantly worse. At first i thought its broken until i enabled the timer and checked again with the turned off display...
Also if anyone cares, the (objectively) best sound quality is with the "Fast" filter, everything else changes the sound as far as i could test.
Also the difference between Low Gain and High Gain is only 5db which is strange. My DAWN PRO has a difference of 10db between low and high gain (especially with sensitive IEM, thats a pretty big difference. My IEM is much louder on 001/100 Low Gain on the DC07 Pro than on the DAWN PRO)
What is also strange is, that the Dongle reports to the OS that it is capable of the following rates
44100, 48000, 88200, 96000, 176400, 192000, 352800, 384000, 705600, 768000
the CS43131 only supports up to 384000, so not sure if this is an firmware bug or not.
May 14, 2025 at 12:43 PM Post #1,924 of 1,929
With our FPGA and the DAC matrix, the DC07PRO can support PCM up to 32/768, and native DSD512.
We have tested the DC07PRO with the screen on and off and there is no difference. May I ask what test equipment is it that you used?
I have a short video of the testing, which shows there is no difference. I will upload this.
I can't upload the video but you can contact me at paul@ibasso.com and I can send it to you. It shows there is no difference with the screen on or off during playback of the signal.
iBasso Stay updated on iBasso at their sponsor profile on Head-Fi.
http://www.ibasso.com/ paul@ibasso.com
May 15, 2025 at 2:45 AM Post #1,925 of 1,929
Sorry for the late reply, i was still doing testing and playing around and so tested several things before looking back here.
I noticed that the HP Filter also only affected the right channel (not both), so i thought, something is wrong with this device first, but then noticed, the Firmware is outdated.
I updated the firmware and i can no longer measure a difference between display on/off, also the HP filter works perfectly fine now, as expected. This is the measurement with Display On
This is with Display Off
Pretty much identical
I measure using an PreSonus Studio 68c
May 18, 2025 at 1:32 PM Post #1,927 of 1,929
May 18, 2025 at 11:18 PM Post #1,928 of 1,929
How do you update the firmware? And how do you know if it's the latest ones?
May 19, 2025 at 12:12 AM Post #1,929 of 1,929
You need a Windows PC. As I don't have one, I used an VM.
I tells you the current firmware in the menu (the last Point). You can get the latest firmware from the iBasso homepage
