Hi there,
As far as the bridged amp is concerned, I think it would be a very overkill to use it as a preamp. If, instead, you want to use it to drive some VERY efficient loudspeaker (Klipschorn?), that could be very nice. In any case, make some computation to understand how loud the combination of bridged Gilmore and hi-eff amp could sound (there must be some formula around here for headphones, just use Watts instead of mW).
I tend to remember that Dr. Gilmore suggested somewhere to add more output transistors to drive 8 ohm and less. I caressed for a while the idea of adding more transistors on one of my two (future and non-bridged) amps, to be able to experiment with my (very far in future) next DIY experiment (maybe a horn speaker). Maybe I'll just put some additional trace in the amp board.
By the way, I recently heard a terrible discussion on the tnt-audio forum (in italian) about a similar subject (if a 3W tube amp connected to a horn loudspeaker may or may not sound loud) and I've seen that audiophiles may hold very religious opinions about this kind of things.
If you're really interested to the idea, since I think you're not religious (in the audiophile sense) I'd suggest you to get a $49.99 Sound Level Meter (SLM) from Radio Shack (I got one one week ago) and to measure, using your favourite record and favourite volume, the max Sound Pressure Level (SPL) from your loudspeakers. Then compute the SPL you could expect with 4.5W of the bridged Gilmore or 1W of the plain one (not sure about the figures). Then lower (or raise!?) the volume knob until you read on the SLM that figure. This not to have an idea of how good it could sound (I suppose better), but just to have a very rough idea of how loud it could sound. In case, the Radio Shack code (the toy is getting out of stock) is 33-2055. Certainly not a professional tool, but useful for rough measurements.
I suspect Jude will ban us from the forum after this very OT discussion...
Massimo
