The Different Types of IEM Connectors
- Thread starter IEMusic
I wonder if something like this can fix the issue of MMCX lifespan:
Just leave it on the MMCX connector of IEM, and use a 2 pin cable at the other end (assuming resistance of this adapter thing is low and that it doesn't affect sound signature).
RikudouGoku
Member of the Trade: RikuBuds
Does look like that adapter wont make fit worse than something like this:I wonder if something like this can fix the issue of MMCX lifespan:
U got a link for this one?
Though the 2 pin female connector part is recessed? Not sure which 2 pin cables can fit this?
RikudouGoku
https://www.aliexpress.com/item/4000240601042.htmlU got a link for this one?
RikudouGoku
This one looks like it will fit more 2pin cables. (also from the same link above.)
ChrisHeld1989
There is also the strange MMCX connector from Obravo with a slit on the outside part or ring. It is a MMCX where the cable can't spin free. I hated this thing on my Obravo Cupid. I grinded down until the slit disappeared, so you can use a normal mmcx.
Photo belongs to glassmonkey reviews
This is the only store I have found that does an angled MMCX to 2 pin. The third customer review confirms that it is a recessed 2 pin female port, not a male one.
https://www.aliexpress.com/item/4000434572042.html
Thanks, good info. Have any of you guys tried them? Am interested to see if these adapter thingies will mess up the impedance or mess with the sound? I'm a bit wary to add something in the chain as such. But might save a MMCX connector on our IEM in the long term so this is worth a consideration for sure. Or just leave a cable on an MMCX IEM permanently and don't cable roll.
zenki
If you've got storage issues then go adapter.
If not cable probably better
I've just ordered that angled MMCX -2 pin and an angled 2 pin- MMCX. They are good to try different cables untill I decide to swap the connectors over permanently.
I do have a straight connector that I bought from Penon (massively overpriced). I don't feel it messes with the sound of the cable. Any cabled adaptor would ideally have the same cable as the one you are trying.
IEMusic
Regarding the connector on the MEST: https://www.head-fi.org/threads/uni...nt-and-impression-thread.924844/post-15868419
The polarity of “qdc” connectors has always been confusing to me. Fortunately, I haven’t had any sound issues as long as I connect the right and left cables the same way.
IEMusic
Regarding 0.78mm 2 pin connections vs 0.75mm 2 pin connections:
https://www.head-fi.org/threads/knowledge-zenith-kz-impressions-thread.698148/post-15861568
IEMusic
Could someone please clarify the specifications of the various KZ and CCA connectors. Are all of the 2 pin plugs 0.75mm? Other than these 2 brands, what other brands typically use 0.75mm plugs, TRN? TIA.
Ferdze
Hi! What kind of connector is this? Camer from a kz zs10. And is it compatible with NX7?
