Doc-holliday
Never did like custom titles.
- Jul 21, 2012
had a feeling someone was going to say that. either way... i like em.
Thats not normal, perhaps you have a fake M50. Did you buy it from an authorized retailer?
My first M50 was underwhelming too and it was because it was a fake. They look exactly the same but sound different.
Howdy,
I got my ATH M50wh a little while ago. I have to admit when I started listening to them I wasn't impressed. To sum it up in a word they sounded "sloppy" to me. I at first went back to using my iems more.
But after listening to them for some hours now I am really liking the sound. They no longer sound sloppy to me and I use them all the time now.
Has anyone experienced this "burn in" period or is this basically all in my head (no pun intended).
Doc
you know, I don't believe in burn in. What I do believe in is your ears just get use to the changes of going from one type of headphone/IEM to another and then you start to see or notice it's beauty.
Again, this is just me.
Yes, exactly the same here! They sounded sloppy in the beginning. Now after a 30-hour-burn in, the sound of the M-50 improved a little and outperformed the s4s, not by much though ~they left the s4s sound a little congested and bloated~
I am not sure if I am giving the M50 enough juice or no. I am using them through my laptop, which has a very good DAC by the way, and I am amping them with the Fiio6. The laptop alone seems to drive them a little better than when combined with the Fiio6. Both ways the M50 can be driven loud enough, but with the Fiio 6 the M50 seem to have a less pleasant sound signature but honestly more punchy mids. I dunno if you recommend a better amplifier that can make the M50 sound a lot better than the Fiio6.
I know a lotta people say burn in is in your mind but I'm glad you experienced the same thing and Im not going crazy
I was able to find acceptable sound through the e6 but I much prefer my e11 with the M50. After a lot of messing around I finally found the sweet spot to my ears using that amp.
(Apple Lossless > ipod 6th gen > ipod EQ setting "treble booster" > fiio L9 cable > E11 -- Low power switch selected ON -- Gain selected HIGH -- eq setting "1")
I know it sounds absolutely crazy to boost the highs in the ipod EQ on the M50 of all things but for some reason the above settings on the e11 by themselves help bring out the mids and muffle the highs but with the eq change, to my ears it gives very nice detailed yet SMOOTH highs. Still detailed but somehow less fatiguing. (BTW that eq setting raises 2k to about 16k in very slight increments -- doesn't touch the lows so you don't get distorted bass).
I can only use the word smooth because it had the same effect on the bass too. Nice and present but just pleasant to listen to.
Anyway, point being,Im sure if you play around with your e6 long enough with different eq settings you can find something that pleases your ears. But the e11 is a definite upgrade in SQ to the e6 IMO. I wish i was an amp expert to tell you more but you can read this thread:
http://www.head-fi.org/t/596482/the-sub-100-portable-amps-shootout-8-1-amps-compared
and this one:
http://www.head-fi.org/t/620775/the-sub-200-portable-amps-shootout-11-8-amps-compared
Thank you sir! Very helpful...
Now there is almost no sibilance whatsoever with the M-50.
NP.. Glad it helped.
Naw....it's all in your head...LOL
hhhhhhhhhhh why? Do you find yours to have sibilance?? :S
anyone agree that the newer production m50 sounds more balanced than the old one? (blue+white box = old; teal+white box = new)
