Dubstep Girl
WA2
Curious to hear how this amp performs though. It should compete with other top level amps
The Zout depends on what output tube you use...if I recall correctly it's around 100 ohms using a 6080, and as low as 50 ohms using a 6528.
I also added an "IEM" mode that trades gain for output impedance, so you can drive 16 ohm IEMs. This is done with a simple resistive alternator, no magic. So the gain is dropped by ~15dB, and Zout is lowered to ~10 ohms.
Although many would argue this amp is only good for higher impedance headphones (over 150 ohms), personally I find many lower-impedance phones (like Grados) sound better with a higher source impedance.
I understand. It IS expensive. Hopefully you believe me when I say that the selling price is based on the cost to build - it is really not the same as the Little Dot amp with an enormous profit margin.
The unfortunate reality is that you just cannot build something in the US at anywhere near the cost (using locally sourced parts) in China. Fabricating the metal chassis for this amp costs me almost the same as what the entire Little Dot amp costs you to buy!
Chinese manufacturers seem to be able to live on very thin profit margins as well.
Every time I've tried to do anything "affordable", I've lost a ton of money. Best leave that to China, I'm afraid. So the stuff I build is at the opposite end of the spectrum.
Pete
Pete,
Looks like a wonderful amp! How would you recommend dialing this in for Grados (say RS-1)? Would you use IEM mode? The 6528? Is the input impedance 50k ohms?
Thanks! --Jesse
