Clutz: "The pitch tone test was centred around 500Hz iirc, so if you had headphones with really unstable frequency response around 500Hz, it could really affect your ability to percieve differences in tones - particularly when the differences become sub one Hz." |
Yes, it was 500 Hz. I don't think the response will vary that much within 499-500 Hz or 500-501 Hz no matter what headphone you use, but I could be wrong. It is difficult to detect very small Hz differences in pitch at this level (unless the tones are played at the same time, then it is easy to detect
much smaller differences, which is why instrumentalists tune by playing at the same time). Of course if someone has perfect pitch, it should be easy (not me...
BTW, 1 Hz at this level is equivalent to about 3.5% of a half step, a small difference indeed.
The reason I included the cents info before is because a difference of say 5 cents at 30 Hz is the same (audibly 5% of a half step) as 5 cents at 15000 Hz, but 5 Hz difference at 30 Hz will be up to 1/4 of an octave (a little more than a minor 3rd or almost 3.16 half steps) while 5 Hz difference at 15000 Hz would be at most .5% of a half step.
I guess what I'm saying is cents would give you a better idea of the amount of pitch difference you can hear than Hz (although you can convert between the two if you know the Hz level).
Also, many things can affect hearing such small differences. If you have a cold and anything to do with sinuses being the most obvious.
