Technical question about sony S639
Jul 1, 2009 at 6:21 PM Thread Starter Post #1 of 2
gabrieles84
Hello everybody, i've just bought a brand new sony walkman S639. I've been very surprised for its excellent audio quality but not for its output power.... now, as wanting to upgrade my earphones, i was wondering that maybe a 32 ohm impedence model (akg k315 or K317) would be too hard to drive for its amplifier .... with the 16 ohm earphones i have (akg k314) i use to listen music with a volume level not lower than 24 and very often near maximum (30), so for me my sony is not as powerful as i wanted it to be, but it's ok... The problem is that i think that with 32 ohm earphone the sound would be too much quieter.... and unaccettable for me.... what do you think about this?
thanks
Jul 2, 2009 at 1:45 AM Post #2 of 2
Not sure if you have volume limiting on. 16 ohms should not be hard to drive at all. I have no problem powering my PFE's which are generally considered hard to drive as far as IEMS go. I'm using a Sony A818 and there's an option under common settings for the volume limiter. Not sure if yours is on or not but you might want to take a look and see if that could have something to do with it.
