pigunios
- Jan 22, 2014
Most of my music is wav or flac 16/44 up to 24/192. Mostly ripped cd's. I just play them 2xDSD. It just sounds better. More clear and analog, in the good sense. It's obvious that if you get a good 2-3 times more expensive dac that it'll equal or better that SQ on pcm. But in my case using coax gives more interference using the pc as transport. Plus I bottleneck the Teac this way in terms of resolution. I guess the transport quality makes a difference. Funny thing is, when I tested Hegel HD11 which I find also wonderful for it's price, and which is optimized to sound best through it's coax-1, I still preferred with a wide margin the usb with 24/96 as maximum resolution! Using a good usb cable makes the transport a non issue for me.
Using such a scenario makes it more tricky than using a high quality stand alone cd player. I had that and replaced it with the Teac dac getting more flexibility, future proof and even better sound for far lower cost. That's what I find great about good dacs, even 1000$ ones. If you're after highest resolution possible then you have to pay the price. As long as it's musical. And not just about the details.
Yes personal preference is of great importance. Like I say to a friend of mine always, don't mind so much of all the reviews. They can be a guideline, to get an idea. But if you don't enjoy yourself from what you hear from the gear, don't bother. It's about having fun and enjoyment.
