krisjan
- Sep 27, 2008
most people here probably know about this tut: How to Build the CMoy Pocket Amplifier
I've decided to give it a go, and just have a q re the parts - Part Lists and Suggestions. Is it worth it to go for higher spec parts? And if so what would make the most significant difference apart from the opamp - caps? resistors? in the tweaks section he mentions some ideas for better caps (not specific brands, model numbers, though): Tweaks. I quote Quote:
I see the BSG CMOY I have has a 1000microf cap?!
Anyway - will this make a big difference or is it not worth it for a first diy amp?
btw space is not a problem for me in terms of this build - i am actually not planning to use this protable - probably i'll just put a 24v supply jack in and use it in some box - it's really just a test/practice first build (if it's nice i'll definitely be using it though
k
For the power caps, 220 µF is adequate, but bigger ones will provide a bigger current reserve, which can be useful in handling high instantaneous loads, like big drum hits. I've tried 470 µF caps in my CMoy amps before, and it does improve the bass handling significantly and they're not all that much bigger than 220s. |
k
