JK1dotNET
- Dec 5, 2001
Hello Fellow DIYers,
Last night I finally got some more time to work on my Szekeres Amp that I recently built. I've started to notice something that I didn't notice before - I'm not sure if it was always there and I didn't notice or if it has only recently started to appear.
As I turn up the volume, more and more distortion is introduced. I thought maybe it was the drivers in my cans, but I tried them on my CMoy and didn't notice nearly as much at similar levels. I threw a scope across the 15VDC connector points on my perfboard, and at low volume, it looks flat and pretty clean, but as I turn up the volume, I see noise that mirrors the signal that I hear. Loud parts show up even more. The more I turn it up, the more I see.
So, is this most likely the cause of the distortion that I'm hearing?
If so, how do I remedy it? Do I just need some big reservoir caps near the perfboard? I added 1000uF and didn't notice any difference. Do I need a supply that can source more current?
Thanks,
JK1dotNET
Thanks,
JK1dotNET
