Shrimants,
I did what you said. I hooked each set up one at a time the same way, with the speakers in the same space. I am using a 2008 iMac intel, with an HRT Streamer II+ USB DAC. I played two different HiDefinition FLAC files from HD Tracks through Songbird. The bottom line is that both set of speakers are so good, it is really hard for me to choose the "best" one! One song seems to sound a little better on the Audioengines, then a different song sounds a little better on the Swans! I've gone back and forth a dozen times and I really can't pick a winner. The good news is either one I pick will be a great decision, there is no bad decision. ( I am going "nuts" trying to decide)
I may have to base it on which one is easier to hook up to the DAC and if I keep the subwoofer, which works best with the sub. Please send me any other detailed instructions in testing them if you'd like, but my other question is related to using a subwoofer. You mentioned not to use the sub DAC if I have a good DAC, (which the HRT is). With the Audioengine, it seems best to run the DAC dual RCA cables to the Audioengine RCA to minijack adapter then into the back of the A5's. Then use the "sub out" RCA jacks on the A5's to run to the RCA hi-pass inputs on my sub. But with the Swans, I have to run the DAC into the sub inputs, then run RCA cables from the sub to the back of the Swan's which have dual RCA inputs. Do you see an advantage to one setup over the other. That might be the deciding factor in my decision. The Swan is about $100 less, but that is not a big factor for me.
By the way, I also live in Oakland County, Michigan. We should get together after this.
Bippie999
From what it looks like, you should have the following setup (For A5's+Sub):
Mac --> DAC (via firewire) -->(RCA) -->Audioengine Speakers --> SubOut(RCA) ---> Subwoofer.
From what it looks like, your DAC simply turns USB output from computer into RCA output. Dont do dual RCA cables. The audioengines are meant to handle the sub output, and I'm assuming it is a powered sub. There should be a low pass filter or some such thing to control the volume of the subwoofer and the crossover frequency. You dont want the dac to send a "full" audio stream to both the sub and the speakers when the speakers (A5's) are completely capable of handling the "what to send to sub" by themselves. The audio should be taking the straightest line path possible, if taht makes sense.
Now if you want to try out the D1080MKII's, I dont know how you hook those up. From the pics I see online, it looks like both have a dedicated subwoofer and dedicated tweeter output. What I assume form this is that either speaker can send power to the sub, but I dont see how to connect both speakers together. The bass/treble knobs on the swans can also change the amount of power/signal your sub is getting. Look into the manual to figure out the proper setup for it, but from what I'm seeing, have the same model as above but different wires:
Mac --> DAC (via firewire) -->(RCA) -->swan Speakers --> SubOut(speaker cable) (Left or Right???)---> Subwoofer.
Once again, there should be absolutely no reason to split your RCA connection in 2. Keep in mind that if you do that, each speaker will only get half the current it was meant to be getting. There should be 0 reason to split it unless you plan on using the split to test both speakers out, but I dont recommend it because frankly, its a pain to test one set and make sure the othe one is disconnected AND that the sub is connected.
If you wanna hang out, I go to Lawrence Tech university. I'm in southfield monday through friday and in novi the rest of the time. PM me if you wanna hang out or have a mini get together sort of deal.
BTW for flac files, it would also work if you just go to your local library and rent a CD and play that. The main focus should be using songs that will push your equipment to its limits. HD Streaming sites will barely give you enough sound quality to have you hear a difference. Sure a flac file is lossless at 16bit, 44.1/48 khz, and 1mbps bitrate, but if you are streaming it from some website, they might be converting it first. I know using linux you can make everything convert to low quality 128kbps mp3 just to deal with bandwidth issues.
The music you use should test out how low and how high the speakers can play. You can play anything from sine waves to actual songs. Here are some great bass tests:
http://sinan.ussakli.net/basstest/
Note that he provides both flac and mp3's where necessary.Use flac. Furthermore, you should be listening to how much clarity and spacing there is between individual instruments, sounds, and notes. Listen for how wide the sound is. For example, if you are listening to classical music, you should be able to close your eyes and visualize where each instrument is on the stage. If you are listening to some garage band, you should be able to pinpoint where they are and how far they are from you, their recording microphone.
IMHO
As I do agree with most of what was said above, I would be very careful about what you say about people that you don't know. This "Jon" at TAI has MANY years of speaker system design experience, has excellent suggestions to system set up solutions and happens to be the founder of The Audio Insider. This can be learned by spending some considerable time conversing with him. (assuming that this was not known)
http://www.theaudioinsider.com/aboutus.php
An excellent read: http://www.audiophysic.de/aufstellung/regeln_e.html
I'm not doubting what Jon knows or doesnt know. I have no doubt that considering he's writing for a rather reputable source, he is more than qualified to be talking about stuff. What I dont agree with is people who piggyback off of others' reviews. At the end of the day, everyone's ears are different. One person may listen to dubstep and say its music while another would consider it noise. One person may say too much bass while another would say not enough. There are definately some aspects that people can listen for based on the reviews of others, but here is one example that comes to mind: Steve gutenberg from Cnet uses UE reference series. I just graduated from Bose On-Ears and Creative EP-630's. I wont know or understand half the junk gutenberg mentions in his reviews because he has more experience with all sorts of different audio things. This other person seems to be basing way too much of his choice on what jon says, and that is what I'm trying to "go against". If bippie cant tell the difference between either speaker AND doesnt know how to properly test in the first place, the proper course of action is to send one back and save yourself the money or to turn it into a truly mind-boggling 4.0 speaker system Or stack the speakers and go all out. Never was I trying to say that jon isnt qualified. Really, its me and bippie that arent qualified, if anything.
