Hiwi
- Oct 23, 2008
Hello.
After my Audio Technica ATH-SJ5 is broken for some time,
I am now seeking an adequate replacement.
Although I've bought in the meantime an Ultrasone HFI-580,
I can only recommend, but it's not an adequate substitute
for my defective ATH-SJ5.
Firstly, the Ultrasone is less suitable for traveling,
other hand, the Audio Technica sounded some way more fun.
Particularly hip-hop was fun anyway right on the AT.
Also, because the Audio Technica is almost impossible to obtain,
I am looking for a worthy successor.
The following criteria are important to me:
- Isolation, since I'm traveling a lot by train
- max. ~ 250g
- Price: max. ~ 80 €
- Bass (especially in Hip-Hop & Electro)
Currently I think the following ones are in my closer choice:
- Aucio Technica ATH-SJ5 (again)
- Panasonic RP-DJ600
- Reloop RHP-10
Can anyone say something about the differences of the three headphones,
or recommend a different for my purposes?
Which one would you buy?
Kind regards
Hiwi
- max. ~ 250g
- Reloop RHP-10
Kind regards
Hiwi
