Possum
- Jun 22, 2001
Does anyone have sound clips or know of music tracks that can really stress an amp into clipping? I just built a Nelson Pass Balanced Line Stage preamp and have suspicions that with the default gain, with a potentiometer only at the output, the amp may be clipping with an input level that is too high, or with sounds that are too "strenuous." If the input level is too high, the alternative is to lower it by changing a single resistor (which many builders have done for better sound quality, and is recommended by Nelson Pass if gain isn't needed), but a lower gain will make the preamp's output too low to use as a headphone amp. I'd also like to avoid using an input potentiometer, since that'll add some complexity that I don't think I want to deal with right now.
