Hi,
I bought a cheapo "Titanium PowPower" 9.6V, 160mAh battery for portable amp use. I also bought the 2x9V smart fast charger, which seems to work great (tested on my other 8.4V rechargeables). However, there are some wierd issues with the batteries, I'll describe the symptoms and possibly somebody has some ideas:
I fully charge the battery and it measures 10.5-11 volts or something high like that. I plug it into the amp and it works for a few minutes, then starts to die (I hear clipping, the LED dims). I pull it out, measure the voltage, and it is ~6 volts. Here is the wierd part, if I wait half an hour, and measure the voltage again, it is back up to 10.5-11 volts! Again I try it in the amp, and it works for a few minutes before dying.
I guess the maxim "you get what you pay for" applies and I should have bought some Mahas in the first place. The thing is that all these 9.6V rechargeables seem kind of "cheesy" and cheapo looking, so it is hard to tell which are legit brands and which are not.
Anyhow, it is an interesting puzzle that someone might have an idea about.
Thanks,
George
Thanks,
George
