aos
May one day solve the Mystery of the Whoosh
- Jun 21, 2001
iPod can also play wav so it CAN be compared to standalone players. I've measured mine with RMAA a month or so ago, and I was astonished at how clean it came out. Granted it was without any load (so it was driving soundcard input directly) but at maximum volume and 0dB test signal (I tested with wav calibration/test signals of course) there was no distortion (not any more than normal). It definitely did not measure worse than some of the larger stuff I have. I'm not at all surprised Stereophile was satisfied with it. When driving headphones I'd certainly imagine it wouldn't match performance of the kind of headphone amps that we on these forums use but as a source it's not bad at all.
I've heard distorted mp3's that others encoded but all that I did myself with LAME came out fine and I listen to classical that has a lot of dynamic range (you have to listen near the max volume most of the time).
That is not to say that when using a different source playing CDs and a proper headamp, with HD-600, it doesn't blow the iPod away. In fact iPod helps you appreciate it more, as you get to listen to it all the time using itself and the earbuds and when you come home you get a treat from your home system.
