thrice
Member of the Trade:Rockhopper Audio
- Mar 25, 2004
I'm trying to set up a STEPS for use with 220V systems and I've run into a problem.
I'm using the Amveco 70053 +/-15 15VAC transformer and all the other standard parts for a STEPS configured for 26-32VDC output.
I should get the following measurements at the test points:
TP1 and 2: ~40VAC
TP3 and 5: ~56VDC
TP3 and 5: 26-32VDC adjustable via the trimpot
Instead I get:
TP1 and 2: 18VAC
TP3 and 5: 24VDC
TP4 and 5: 22VDC when I adjust the trimpot it does not alter the voltage at all.
I've replaced the regulator, the transformer and all the diodes and still no change. Any help would be greatly appreciated. And yes, I do have it plugged into a step up transformer set to 220VAC.
Thanks,
thrice
TP1 and 2: ~40VAC
TP3 and 5: ~56VDC
Instead I get:
TP1 and 2: 18VAC
TP3 and 5: 24VDC
Thanks,
thrice
