- Mar 29, 2003
Stello U3 - 24bit 192kHz USB interface
Very good Headfi Review HERE
6moons Review Here
The latest USB interface from Stello is now in. And boy does it sound good This is the best way to connect your non-USB interface Dac to a computer. Or you can also upgrade your USB dac that only does 16/44.1 input. But make sure your Dac section can process 24/192.
Click the Info Link for a great unbiased review.
Features:
USB Audio Class 2.0 compliant:
Asynchronous synchronization mode
High Speed Bit Perfect Audio Data Stream up to 192kHz sampling rates
Master clock:
Super low jitter 2 external clocks
Sampling Frequency 22.5792mHz/24.576mHz for multiples of 44.1kHz/48kHz sampling rates
Resolution:
Standard sample rates 44.1, 88.2, 176.4, 48, 96, 192kHz/24bits Audio
Input:
1 USB 2.0, Type B connector Galvanic Isolated, Up to 192kHz sampling rates
Outputs:
1 COAX 75 Ohms, Gold Plated RCA Connector
1 AES/EBU 110 Ohms, Neutrik XLR Gold plated contacts
Lock indicator:
LED on the front panel
Platform Support
Customized Windows Driver:
Windows XP, Windows Vista, Windows 7
Natively supported by Apple Mac OS X
Dimension:
100 X 36 X 100mm (WHD)
Stay updated on Moon Audio at their sponsor profile on Head-Fi.
