MiChael.
- Jul 13, 2004
If you do double blind test with output levels matched within like 0.5db or less, I'd say it would be VERY hard to tell differences with most sources. Maybe like flat frequency response and over 90db SNR would mean already it would be hard to ABX it.
Anyway blind tests are absolutely, if someone can "guess" over 60% right of let's say 20-30 rouds, then it mean something.
Anyway double blind tests only show there is difference, not which one is better. On the other hand it doesn't matter a damn thing which one is better, cause it's subjective personal preference. Does it matter what the majority think, hell no.. it's personal.
The problem with tests is still that if someone is able to test some small sample succesfully, how big the difference is for day-to-day listening. Can anyone actually hear it.
Anyway listening fatique is almost impossible to blind test.
Originally Posted by rumatt /img/forum/go_quote.gif This is very true. It's also true that the placebo effect is strong beyond what many people believe. There's one very simple way to prove the differences that you hear: double-blind listening sessions, where you consistently identify the differences correctly. Without doing this, there's no real way to rule out placebo. |
