jimbobuk
- Aug 11, 2002
I got home tonight and just happened to look and notice that the light was off on my Stax SRM-717, i assumed it'd had had the power switch turned off, but sadly it hadn't.
I've checked everything, moved it out so i can get a good look at it, checked the fuse in the power cable, nothing.
It just doesn't power on, no light.
I've done a bit of searching and heard that most folks don't recommend leaving it on all the time, I've always thought it was the preferred thing to do with hifi equipment so mostly i've had mine on all the time. It gets hot but not THAT hot, well now its not working its gone cold
I'm based in the UK, and brought it from Simply Stax.. the site is down now with phone numbers to phone for support.
What's the verdict on this kind of symptom, i've shined a torch inside the thing and can't see anything noticably fried/burnt, I don't fancy really taking it apart as there must be some high voltage things inside. Is there any chance that there is a fuse inside that can blow and just be replaced.
Has anyone had their 717 repaired, preferrably in the UK but i'd be up hearing about any experiences at this point.
Further reading and i notice that people don't recommend leaving headphones attached, potentially doing damage to them. Well i've left my Omega's attached for a good while now, and i've not had chance to use them lately either. I'm now worried that they could be damaged too, though am hopeful that they wont be.
Bah, frustrating... Any one got any advice?
![frown.gif](http://www.head-fi.org/forums/images/smilies/http://hfimage.head-fi.org/smilies/frown.gif)
