MrHaelscheir
I can say that at least when I took in-ear measurements at an audition, the FR was almost perfect relative to my personal neutral target. Assuming a good seal, it is virtually dead flat (for blocked ear canal measurements) between 70 Hz to 4 kHz other than an upper midrange elevation and some treble waviness, so if you want it to be more neutral, I would put the following parametric filters (immediately compatible with Equalizer APO):Was wondering if any X9000 owner EQ his unit, and if so, with what settings?
I find I have good results on my 007A and 009 when applying convolution filters from AutoEQ. If only we had those for X9000....
# Bass shelf linearization filter assuming a good seal on your head:
Filter: ON LSC Fc 33 Hz Gain 5.80 dB Q 0.710
# General bass shelf; adjust to taste:
Filter: ON LSC Fc 100 Hz Gain 0.00 dB Q 0.670
# General lower midrange adjustments to correct for thinness or excessive fullness or bloat:
Filter: ON PK Fc 300.0 Hz Gain 0.00 dB Q 0.500
Filter: ON PK Fc 600.0 Hz Gain 0.00 dB Q 0.700
# These are the filters for flattening the upper midrange boost which I attribute to the leather inner lining of the pads:
Filter: ON PK Fc 626.0 Hz Gain 1.20 dB Q 10.000
Filter: ON PK Fc 763.0 Hz Gain -1.40 dB Q 5.000
Filter: ON PK Fc 1132 Hz Gain -3.50 dB Q 2.000
Filter: ON PK Fc 1667 Hz Gain -1.30 dB Q 5.000
# Adjust the below filter's gain depending on the 3 kHz peak adjustments; e.g. change it to 2.30 dB if you choose to not apply the next two filters:
Filter: ON PK Fc 2809 Hz Gain 4.80 dB Q 2.000
# 3 kHz peak adjustments; this is best adjusted by ear by checking if you hear a 3 kHz peak in sine sweeps or pink noise:
Filter: ON PK Fc 2472 Hz Gain -2.60 dB Q 6.000
Filter: ON PK Fc 2858 Hz Gain -5.50 dB Q 4.000
# Optional ear-gain boost toward free-field levels; adjust to taste (2024-05-05: Outdated/incorrect; see https://www.head-fi.org/threads/rec...-virtualization.890719/page-121#post-18027627 (post #1,812)):
Filter: ON PK Fc 2300 Hz Gain 5.00 dB Q 1.000
Filter: ON PK Fc 4000 Hz Gain 6.00 dB Q 1.000
# The following smoothening of the area between 5 kHz to 7 kHz may depend on your own ears and is best adjusted by ear with sine sweeps or pink noise:
Filter: ON PK Fc 4500 Hz Gain -1.70 dB Q 7.000
Filter: ON PK Fc 5377 Hz Gain 2.70 dB Q 7.000
Filter: ON PK Fc 6602 Hz Gain -4.60 dB Q 5.000
# The below filter flattens a peak measured on my ear prior to applying an optional high shelf filter for getting top octave levels closer to my Meze Elite; you can also adjust this by ear:
Filter: ON PK Fc 11000 Hz Gain -4.00 dB Q 6.000
Filter: ON HSC Fc 13605 Hz Gain 5.70 dB Q 0.710
This is the style of EQed flat that had me preferring my EQed Meze Elite's presentation over the Sennheiser HE-1's.
