Here are some in-depth comments from a very knowledgeable head-fi member that may have interest to those here:
The T2 operates at 500V+- internally, and is DC coupled; the Megatron is 400+- and is AC coupled (coupling caps).
In reality, the T2 has a few DB more of headroom, and the advantage of being DC coupled (more clarity to the sound, although slight), with the disadvantage of a thermally unstable battery per EL34 to keep the output linear, and rare transistors. They each output 10 watts of pure class A per EL34, 40watts in total, with about 15-18ma to the headphone.
The Megatron uses an EL34 CCS per EL34 output tube. This is a bit "softer", but also a lot more thermally stable. Overall, the biggest difference in sound is the coupling caps in the Megatron, and of course, the tube choice between the amps. The sound of the Megatron will depend enormously on the tubes you choose, however, much more than the T2. In this sense, the Megatron is a much more traditional tube amp. The curves of the tubes will really determine the sound, whereas the T2 pretty much forces any tube to behave in a linear manner, using the brute force of a BJT topology and 231 semiconductors.
The T2 and Megatron are potentially very similar in performance. The Grand Cayman is very similar to the Megatron, it just uses DHT tubes. The T2 will always be slightly more detailed, and the other amps slightly more musical. We are talking THD of about 0.1% on a tube amp in either case, which is excellent. And all the distortion is harmonic, of course. The E180CC tubes in the Megatron give the amp more clean gain than you could ever use. A tube rectified Megatron or Grand Cayman is very expensive.”
I believe the ballpark is a tube rectified megatron is going to be near T2 pricing (aka 10k+). A “standard” is found closer to 6-8k depending on the builder.
My previous post had an autocorrect issue, I meant to write Novem. Which is a less expensive (~$3500?) limited amp Mjolnir offered for a little while that may have synergy with the srx9k (akin to the he90 with the hev90). Only 1 person has verified this, but imo it makes sense given the edginess the srx9k can occasionally exhibit. I heard several people prefer the original sr-omega v1 (not the v2) with weaker more tuby amps like the hev90 vs more power with something like the carbon.
