johnation33
- Dec 14, 2007
Hi,
I noticed today that whenever I moved my head I would hear a scraping noise on my left earpad of my pro lambda speakers. I checked to see what it was and basically the inside driver system (basically the foam+driver inside the grill outer covering) is loose, so the entire thing shakes/moves whenever I move my head. My right earr driver system is secured in place. Now I think I can fix this manually, but I was wondering how to open the grill, and what exactly holds the driver system in place, screws or adhesive or glue?
Sound quality is not affected, only when I move my head but thats just the physical sound of the foam+inside of the earspeaker rubbing against the outside grill frame.
