error401
- Oct 11, 2006
The order of magnitude is in the 100s of thousands, but even so for things like your swap file, it wouldn't be that hard to amass that many writes to a block over the lifetime of a computer. Modern flash is getting better by the day in that respect though, so it's quite possible that it's no longer a major issue. There's also always wear leveling which, for a standard workstation type use-case probably increases lifetime several fold easily.
They're still only really suitable for very specific cases though. The biggest advantages being reliability and power usage. I definitely wouldn't be adopting the tech myself for at least a few generations. When SSD is available at a similar price point (with less capacity of course) it might be a viable option for me, since I don't tend to need huge capacity all the time (would be fine to attach an external disk for that). Only if battery life is of utmost importance to you can I see it as a serious consideration as the only disk in a system.
