My Blue Snowball works with my PS4, and also works with my PC. I am wondering if I can use something like a USB splitter and have it go to my PS4 and my PC at the same time.
Not a simple y-cable/splitter, no. You can't have it connected to both places at the same time. But you CAN get a USB Switch so you only need to press a button to change between devices.
EDIT: Assuming it is USB connected, which I recall the Snowball is. If it is connected via a 3.5mm jack, then by all means just use a splitter. (it MIGHT affect your sound quality, but I don't think it'll do that much.)
Dang, and I need to record my voice at the same time for both so a usb switcher won't work. And then it doesn't seem to me that there is any "clip-on" usb mics. It seems like every one I find is on a stand. Well thanks.
Btw, if you dont mind, would you happen to know of any usb mics that would just clip on to my shirt? I can find tons of 3.5mm mics but no usb mics. Anyway thanks again!
