OG10
Hello guys, I am very conflicted at the moment between two options. It might seem a bit absurd, but this is what is going through my head.
Well first of all I only have a project-heabox SE as an amplifier, and its doing a good job, but its not all that detailed and lacks real punch that I am after. I have some HD600 which will be the recipient of whatever I buy. I need a DAC primarily to feed my Naim Nait, so I really am after good DAC, but if possible a headphone amp too. Now here come the hard choices.
I was okay till I found firestone audio, because I was sent on the Stello DA100, now having had a look at firestone website, I could have the DAC, the HPAmp and two conditioned PSU all for the price of the Stello.. I am just flumuxed as to what I should do.
Is the quality difference between the Stello and Spitfire that different? And if I do get the Stello, my current headbox will need upgrading anyway? I know in the meantime it could add some great clarity for the Naim, but the idea of owning so much via firestone is tempting..
Please offer any advice you can. My maximum budget is USD $700, and they must deliver to the UK. My musical tastes are between Classical post 1900 and Rock. So please use your acumen to suggest what I should be buying?
Whatever I get I shall review in here
Regards
Wasp
Regards
Wasp
