SemperFidelity
- Nov 12, 2005
You should listen using source material you're very familiar with, and if possible with the same cd player and amplifier you intend to buy. Several sorts of material help; Male vocals, big bands, symphonic, and small jazz groups would cover the ground for me. When you're close to a decision, you should audition in your own listening room. (This implies buying from a good dealer. )
As some above have pointed out, reviews should be used only to indicate what you might want to listen to... Your listening/taste/preferences are yours alone. And a deliberate approach to the purchase can only help.
If this is your first system, a pitfall that many fall into is to be bowled over by a dramatic system; a system that is a bit louder, with bass and treble tipped up slightly will stand out on the demo floor. A bit of a peak in the 130 Hz area or so will excite the chest cavity ("you could really FEEL the bass"). Such a system is very difficult to live with over the long term.
Listening to live acoustic music can help, as unamplified instruments can be used as a "transfer standard'" since their sound is consistent; electronic instruments are not, since their sound can be changed by turning a knob.
