renenkel
Hello -- Can someone please help me with my speaker? It's a JBL-800 that I've had since the mid-1990's, and it started buzzing. I removed the grill (glued on, thanks JBL
) and saw this. There was all this crumbly stuff that looked like old weatherstripping lying on the bottom, and the cone of the woofer looks completely unsupported. An;y idea what happened? Can it be fixed, or does the woofer need to be replaced? If it needs replacing, do I need a specific kind, or will any woofer with the same size and ohms do? This was the right speaker...would the left also be likely to go soon too and should I replace both? I'd be grateful for any advice. Thanks, Robert
