Speaker and Receiver cable/wire question
Dec 6, 2014 at 1:32 PM Thread Starter Post #1 of 2
feedworks
Hello,
I am a new user and beginner with very little knowledge in audio equipment. I bought Klipsch Quintet speakers and Denon S900 receiver. I have the cabling done (inside walls) in my condo and I have the following question.
One end of the cable to connect speakers is split into two wires to connect to the positive and negative. Other end where I need to connect to the receiver is attached to a single plug (looks like an RCA plug.. not sure). Denon S900 receiver doesn't take that plug. It takes positive and negative wires. Is it ok to cut the plug and split the cable and connect to my receiver?
Thanks,
Kumar
Dec 12, 2014 at 2:41 AM Post #2 of 2
Hi Kumar,
   This is not the right forum for this exactly, but can you take a picture of the plug that's on the receiver end? I don't want to lead you in the wrong direction, but cutting the cable will most likely be fine assuming that is the correct one for where you think the cable runs.
