Zoide
- May 2, 2004
But isn't that belief the one that the whole concept of jitter is supposed to counter?
I had read in some other thread that, although you'd think that the same 1's and 0's are the same 1's and 0's in every digital out, the *timing* of them is extremely important. \
AFAIK, "jitter" is the error in that timing and the reason why an expensive source will usually have a better digital out than a cheap one.
Originally Posted by Budley007 My 2 cents on soundcard digital out. We've discussed it here before. Bit-perfect digital output cannot be improved. You can spend $40 or a $1000 on a soundcard. Provided they produce "bit-perfect" output, you'll find no difference. The sound quality will be totally dependent on your DAC/amp and interconnects. Spending more money there will be a much better investment. |
