PurpleAngel
Two other combo options I would appreciate some feedback on!
T70 + NFB 11 or 15
Vs
SRH1540 + NFB 11 or 15
Any opinions?
The Shure would be so easy to drive, you could just get a FiiO E17 DAC/amp, $140.
T70 + NFB 11 or 15
Vs
Any opinions?
Only problem is that the Fiio E17 doesn't seem to provide me with the optical input I desire for EAX surround from an internal card such as the SB-Z.
The more time I spend on this forum reading, the more uncertain I get as to what headphones+DAC/amp to get in the end
Btw, found this post about NFB-11 and clicking relay sound that got me a bit worried.
http://www.head-fi.org/t/730709/is-the-audio-gd-nfb-11-2014-a-clear-improvement-over-the-ehp-o2-o2-odac-driving-an-he-500#post_10941691
"Everytime I pause and play a song, a relay sounds. This causes a continuous 'clic', 'clic', 'clic', when I'm pausing and playing. Also when pressing play after a pause, along with the annoying 'clics', 0.5 seconds of music are lost until the relay allows the sound signal pass again. I hate this behaviour."
The SB-Z does all the EAX surround sound processing and then sends that processed headphone surround sound thru optical to the E17 (E17 has USB, optical & coaxial inputs).
The SB-Z takes in 6-channels of audio and converts it to 2-channel virtual headphone surround sound, so the E17 does on have to do any surround sound processing itself.
The E17 takes in the 2-channels of (digital) headphone surround sound, runs the digital audio signal thru it's DAC, converting it to a analog audio signal, which is then sent to the E17's headphone amplifier.
I do not have any issues like that with my one year old NFB-15.32.
Good to hear, I guess the NFB-11 and NFB-15 are nearly identical except for the DA chip?
Just thought it a bit of odd solution that Kingwa gave him to his clicky relay problem.
"Kingwa already gave me a solution for (2). I must open the equipment and cut a cable to disable the relay. One day I will do so, and I thank Kingwa for the solution, but opening and cutting cables is not what I expect from a brand new product."
Btw, there isn't much of a price difference between the T70 and the T90, I know the T90 are open cans and wonder if you have had any experience with them?
I only have the T70.
I have had no problems with my NFB-11. Haven't heard of anyone else with a problem like that.
Ok, thanks!
New T70's go for 486 USD here in Sweden, while I can get new T90's for 513 USD. I have never had an experience with open headphones and wonder if it would get annoying with outside noise. Also really don't know how much sound they leak.
Open headphones are usually not bothersome to others, at least in a home setting and the other people are in other rooms.
I lived in an apartment, with neighbors kids playing just outside my windows, had to use the closed T70s to block the noise.
Do you feel that NFB-11 produce a more clinical and unforgiving sound signature?
I think it is very transparent, producing an accurate sound signature. I don't like "colored" amps
