wppk
Maybe this thread will not be at the right place, but I couldn't find a better one. I would like to tell about something amazing I recently discovered in an auction sale : the spl vitalizer stereo mkII-T.
http://fr.audiofanzine.com/exciter-enhancer/spl/stereo-vitalizer-mk2-t/ ( sorry it's in french but you can google it to have it in english. Don't go to the oplug in, but to the hardware machine, that is told to mork much better. )
As I am using it with my headphones, I think that you guys who are looking for sound perfection and optimization should use this. To make it short, this is not an equalizer, it works with amplifing the harmonics that mp3 make disappear or sound poorer. You have to balance it by hear, and I give you here the positions of the know I found the best.
drive : +3
sound soft : first black bigger point on the right ( like ten o'clock)
compression : around 6
mid hi tune : 2.2
process 11
lc eq 10
intensity between 12 and 13
stereo explander : 13
you can try many other positions fittng your ears, but this one sounds the best to mine.
of course, this is not dedicated to mp3 only, it also works wonderfully with perfect wav files.
press "the active" knob, and you will find the sound really beautiful, and will catch the whole of the interest of the machine when you press it off, because the sound of your heaphones will then sound very poor compared to what you just heard a second before. And you will find it hard to believe that your beloved headphones sound so empty when the machine is off, hard to believe that this is here the unchanged, natural sound you had been dealing with for years. But it is !
I tested it with my stax lambda pro , omega 007, sony mdr sa 5000 sennheiser hd800 and a good bunch of collector akg form the eighties, this is really a great enhance, that does not "damage"' the sound, nor make it sound artificial.
it has no plug for headphones, cause this is an effect that has to be plugged between the source and the amp.
you also can use it, of course, on loudspeakers, thing that I didn't try because my system doesn't allow it currently.
the price is rather high if you buy it new, around 700 euros, but a second hand working one will be a very good buy.
drive : +3
mid hi tune : 2.2
process 11
lc eq 10
