Sound card with multiple SPDIF outs...
Feb 28, 2006 at 2:24 AM Thread Starter Post #1 of 11
jhenderson010759
I am looking for a modern PCI or Firewire-based sound card featuring one SPDIF input and three to four SPDIF outputs which may be used concurrently under Windows XP. DirectSound drivers are required. D/As are optional. Flexible on price.
Any suggestions?
Feb 28, 2006 at 4:13 AM Post #2 of 11
Edwood
1/2 hamster, 1/2 Turkish∙ Blueteething
Cage
RME Hammerfall HDSP 9652 has 3 optical SPDIF outputs.
http://www.rme-audio.com/english/hdsp/hdsp9652.htm
A bit spendy, though.
If you are not concerned with with the small degradation you will get with using a toslink distribution amplifier, you can use what I do, which is a 4 output Toslink Distribution Amplifier (Splitter). Much cheaper solution.
Toslink Digital Splitter
http://www.inday.com/tlda1/tlda1.htm
Coax Digital Splitter
http://www.inday.com/vda-1/vda1.htm
Then you will need a Soundcard with a single input and output.
-Ed
Feb 28, 2006 at 7:21 AM Post #4 of 11
Edwood
Cage
Originally Posted by jhenderson010759
Ed -
Thanks for the reply. I will download the RME manual. But, to clarify, I intend to drive different signals to each SPDIF output simultaneously. So, a dist box won't work for me.
Ah, more of your crazy cool testing?
Sounds interesting.
I hope the RME HDSP 9652 is up to the task.
-Ed
Feb 28, 2006 at 1:37 PM Post #5 of 11
jhenderson010759
Originally Posted by Edwood
Ah, more of your crazy cool testing? ...-Ed
On my primary stereo rig, I am experimenting with ambience recovery. I'd like to use some MTMs that I built last year for the rear channels. But, they use DCX2496 electronic crossover, which has digital inputs. I want to keep all signals, including the ambience channels in the digital domain until amplification.
I found a piece of SW on SourceForge which implements Dolby ProLogicII music mode via a PC through a soundcard. So, I'm planning on building a quiet PC to run this SW.
Feb 28, 2006 at 3:30 PM Post #6 of 11
dwk
The standard answer for this is the Lynx AES-16. 8 pairs of ditigal outputs. It actually is AES/EBU out, but you can generally convert this to spdif-compatible with an xlr->rca cable. If not, you may have to get transformers to do it.
Alesis sells the AI-4 which is a 4-spdif<->ADAT box. 8 channels supported at 44/48, and I think you can run at 96 with a reduced channel count. Pair it up with say an Emu1212 which supports ADAT
The Emu 1820 versions have two useable spdif outputs - one on the pci card and an optical output on the dock.
Mar 1, 2006 at 6:29 AM Post #8 of 11
thomaspf
Hi Edwood,
are you sure the RME card supports S/PDIF on all 3 optical ports. I was looking into that a while back and it appeared as if it only supported ADAT on these optical ports.
This would be a pretty cool solution if you could just drive these ports in S/PDIF mode like a multichannel card and get all channels of a 5.1 system on digital outputs.
Do you know whether this will work with the NVIDIA audio drivers that come with Theatertek?
Cheers
Thomas
Mar 4, 2006 at 5:16 PM Post #10 of 11
jhenderson010759
...seems like it will work also. It has three SP/DIF outs via a four-pole mini-plug. The Creative drivers disable digital outputs when the 2ZS is performing Dolby decoding, but when used in conjunction with MatrixMixer, the board will be operating as a pass-thru six channel output card, which should be fine for my purposes.
The drivers appear to feature a bit-perfect mode which bypasses any up-sampler.
Mar 15, 2006 at 7:00 PM Post #11 of 11
jiiteepee
Creative card models equipped with AUD_EXT connector:
Application circuit to connect
6 digital INs (3 stereo) and
8 OUTs (4 stereo)
at the AUD_EXT-Connector - http://electricstart.de/site/optical.htm
jiitee
