Sound Card Mic In Port Question
Sep 21, 2004 at 4:35 PM Thread Starter Post #1 of 5
insomniac
Is it possible to hook up the line level out of a music player such as the iPod to the mic in of a computer sound card and have the music play out of the computer speakers?
Sep 21, 2004 at 5:37 PM Post #2 of 5
Better use a line input on the sound card. Mic input may have a fixed level gain stage which is not desired with line level signal coming out of your ipod.
Sep 21, 2004 at 6:29 PM Post #4 of 5
Don't know about laptops, but sound cards (integrated) generally do offer "line-in". Though usually it's the same port as the mic in and then there is probably some software control whether it is amplified or not.
Sep 21, 2004 at 6:45 PM Post #5 of 5
Thanks, breez, that was helpful!
