Sound card for Fidelio X2
Jan 19, 2015 at 2:21 PM Post #2 of 6
http://en.europe.creative.com/p/sound-blaster/sound-blaster-z
or
http://en.europe.creative.com/p/sound-blaster/sound-blaster-audigy-rx
I use an older Titanium X-Fi and I still think it is a good card. I never go beyond 25% volume on most headphones. So they should easily be able to drive the X2.
Jan 20, 2015 at 7:39 AM Post #3 of 6
my integrated SupremeFX was totally crap with X2 even if the volume was strong.
Are u sure theres big difference as amplification between integrated and these sound cards ?
Jan 22, 2015 at 3:48 AM Post #5 of 6
Hi, I use an dac/amp, Meridian Explorer2 which drives X2s very well.
That said, if you want an internal soundcard, make sure it has low output impedance (3 ohms or less) as X2s are low impedance headphones.
Jan 23, 2015 at 1:05 PM Post #6 of 6
I see the specifics of Creative ZXR ( same chip amp of Essence STX II ) and i saw it give at 32/33ohm 25mW in "High Gain" mode and 70mW in "normal gain".
Are you sure Fidelio X2 or Sennheiser 598 is easy to drive by this cards ?
