Sound Blaster X7 alternative help
Jan 4, 2023 at 9:25 AM Thread Starter Post #1 of 10
holyxiaoxin
I have a Creative Sound Blaster X7 and it has served me well(died). It's an easy to use featureful speaker amp. I would like to find a replacement for it but I've searched quite abit but unable to find an alternative. My budget is $500. Here's what I need:
1. Power my bookshelf speakers (E-MU XM7) using bare +/- wires (I don't know what they're called, please let me know if there's a term for it). They're awesome and I'd love to keep them. It's been with me for 10 years.
2. Receive input from PC via USB.
3. Bluetooth (optional), to receive BT inputs, so I could play them on my speakers.
Most amps don't output to bare wires unfortunately. I think they output to coaxial cables.
Jan 4, 2023 at 10:24 AM Post #2 of 10
Maybe keep using the X7?
Jan 4, 2023 at 1:36 PM Post #4 of 10
Jan 4, 2023 at 5:45 PM Post #6 of 10
Jan 6, 2023 at 2:46 PM Post #8 of 10
any idea what inputs are these and how do i connect bare wires to it?
Those are not amplifier outputs, those are (RCA) line-outputs, those (Audio Output) are what you connect to the speaker amplifier.
Guess it acts like a pre-amp, it increases the signal strength (loudness) that you feed to the speaker amplifier (or other amplifier).
Jan 12, 2023 at 6:18 AM Post #9 of 10
There's the SMSL AD18 which I think would fit the bill and keep under budget. I've had both of the X7's (reg and LE) and it's ok, but the opamps are really showing their age and no software updates for a while last I checked. The SA300 is even better if you don't need the headphone jack.
Jan 12, 2023 at 6:35 AM Post #10 of 10
This looks good! thanks for sharing. Is SA300 identical to AD18 minus the headphone jack?
