Sound blaster X-Fi Surround 5.1 USB or Full unit?
Oct 17, 2012 at 10:39 PM Thread Starter Post #1 of 9
Proxymanity
Hello guys. I wanted to ask if any of you have any expericence with the Creative Soundblaster X-Fi Surround 5.1 Pro USB Audio System with THX SB1095
[size=11.818181991577148px]or the [/size]Creative Soundblaster X-Fi Go! Pro USB Audio System with THX SB1290
As far as I can tell, the first is the a full sized version while the second is aUSB plug and play version. I want the surround sound for gaming, but also better sound quality than my onboard realtek soundcard. Any help or advice is appreciated!
Oct 17, 2012 at 10:48 PM Post #4 of 9
If you want 5.1 output, you need to get the X-Fi Surround 5.1, the X-Fi Go! only has 2.0/2.1 output.
Also, do try to find a X-Fi Surround 5.1 non-Pro version (SB1090), as "Pro" versions come with a software package that does noticeably worse processing, and is to be avoided. This affects both the X-Fi Surround 5.1 and the X-Fi Go!.
Oct 17, 2012 at 11:26 PM Post #6 of 9
There is a reason for that price difference, although most of that related to the X-Fi Go!, where the Pro version (SB1290) has a hardware glitch, a bad audio processing software package and 24/44.1 output while the regular version (SB1100) has an adequate software package, no glitches whatsoever and 24/48 output. Haven't heard of a revised Pro model to fix the glitch at this time.
The X-Fi Surround 5.1 Pro (SB1095) differs mainly on the software package. Unfortunately, the packages aren't interchangeable by default.
Oct 18, 2012 at 2:00 PM Post #7 of 9
Wait, I thought the SB1095 was the 'pro' version while the SB1290 was the regular version?
And I'm mostly in it for the surround sound so the USB (No 5.1) would be a second choice.
Unless you could recommend another thats around the same price.
Oct 18, 2012 at 2:07 PM Post #8 of 9
The SB 1290 and SB1100 are the Pro and regular versions of the X-Fi Go!, not the X-Fi Surround 5.1.
Considering you're looking for a 5.1 unit for gaming, then the X-Fi Surround 5.1 (SB1090) is my recommendation. If you can't find the regular model, the Pro model (SB1095) will also work.
