waveweave
- Jul 27, 2009
hi, I wanna do a project which incorporates weaving audio cables or just wire into a fabric transporting sound.....
would it be possible to create a surface out of wire which does that? what wire would be suitet best and is there a limit in length (or can the sound travel hundreds of meters..and does anybody know where to get say 200m audio cable?
thanks
thanks
