Originally Posted by hciman77 /img/forum/go_quote.gif
anything above 22.05khz is gone forever and changing the bit-rate to 24 pads the sample with 8 zeros as far as I know.
Originally Posted by nick20 /img/forum/go_quote.gif
In lamens terms, this means? I don't know anything about upsampling, etc. I have heard of it, but that's about it.
So it is probably better to run in 16-bit then...
Sorry if I confused the issue
A CD player that uses 16 bit sampling cannot extract more bits of information if it is running at 48KHz, 96KHZ or 192KHz, nor can a CD player get more than 16 bits off the CD even if it is a 20 bit or 24 bit CD player.
Having said that you might find it difficult to actually buy a 16 bit CD player new, some are 18, 20 or 24 bits some are 1 bit (but sample more frequently and use a rather different system) .
SACD is different again, but it requires a special player and DVD-A is like CD but can play audio at 16, 20 or 24 bits and can do sampling rates up to 192khz. This theoretically gives you better sound as in principle you can record frrquencies up to 96Khz ideal for annoying your pet bat.
The short answer is dont worry too much about the bits or the khz, worry about what it sounds like and only you can judge that.
For what it is worth I own 3 home CD playing devices , one is a 1 bit and samples at 352K, one is a 24 bit 96khz and one is an 18 bit and oversamples at 8x the standard 44.1 sampling rate - they all sound pretty much the same to me.
